Mon May 20, 2013 10:09 pm
Hi,
Does anyone out there have a AC9 and a telephone splitter (like http://www.radioshack.com/product/index.jsp?productId=3584353)?
Is it possible to set identical power levels on two lights by plugging in a phone splitter into the AC9, then connecting each output from the splitter into the two lights? If you don't have two lights could you check to see if the output from each side of the splitter works?
I have two AB 800's and a Pocket wizard mini and a flex. My AB 800's are physically close and need identical power settings. I'm contemplating purchasing a AC9 to control power levels from the camera. I'd really like to avoid purchasing an additional flex and AC9 to get this setup working if possible.
Thanks.
Tue May 21, 2013 12:17 pm
Dunno about Pocket Wizard, however, this will work with CyberSync + model remotes.
