| how i can connect an octagon softbox with E640 ? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4057 |
| Author: | raed [ Sun Jun 02, 2013 2:19 am ] |
| Post subject: | how i can connect an octagon softbox with E640 ? |
dear, I have problem connecting the Fotodiox 10SBXPPT60OTEZ Pro Studio Solutions EZ-Pro 60-Inch Octagon Softbox with Speedring for Profoto Compact Lights Series D1 250 (Black) with e640 http://www.amazon.com/gp/product/B003EW ... UTF8&psc=1 so what do I need for perfect connecting with the fingers of e640? |
| Author: | kenyee [ Sun Jun 02, 2013 4:07 pm ] |
| Post subject: | Re: how i can connect an octagon softbox with E640 ? |
raed wrote: I have problem connecting the Fotodiox 10SBXPPT60OTEZ Pro Studio Solutions EZ-Pro 60-Inch Octagon Softbox with Speedring for Profoto Compact Lights Series D1 250 (Black) with e640 Don't you mean this one? http://www.amazon.com/Fotodiox-10SBXAB6 ... im_sbs_p_4 The one you linked is for Profoto heads... |
| Author: | raed [ Mon Jun 03, 2013 12:21 am ] |
kenyee wrote: raed wrote: I have problem connecting the Fotodiox 10SBXPPT60OTEZ Pro Studio Solutions EZ-Pro 60-Inch Octagon Softbox with Speedring for Profoto Compact Lights Series D1 250 (Black) with e640 Don't you mean this one? http://www.amazon.com/Fotodiox-10SBXAB6 ... im_sbs_p_4 The one you linked is for Profoto heads... dear it same what you link also is is a Fotodiox not profoto so please do you have an idea and thank you for replay. |
| Author: | kenyee [ Mon Jun 03, 2013 9:58 am ] |
? Which one did you buy? :? If you bought the one you linked, it won't work because the mount is wrong. If you bought the one I linked to, it should work fine. |
| Author: | raed [ Tue Jun 04, 2013 1:48 am ] |
kenyee wrote: ? Which one did you buy? :? If you bought the one you linked, it won't work because the mount is wrong. If you bought the one I linked to, it should work fine. thank you for replay I bought the one which I link so what can I do now is there any solution or I should replace it with one that you link it to me ? please try to give me other solution instead of replace it thank you again |
| Author: | kenyee [ Tue Jun 04, 2013 10:52 am ] |
raed wrote: thank you for replay I bought the one which I link so what can I do now is there any solution or I should replace it with one that you link it to me ? You should be contacting the Fotodiox folks and ask if you can replace the Profoto mount w/ an AB/Balcar mount. Looks like it might be possible, but only they would know for sure and whether you can buy the mount separately... |
| Author: | la.mike [ Fri Jun 07, 2013 9:02 pm ] |
I have the same softbox which has a replaceable insert. You can just buy the Fotodiox AB insert which is about $9.00. raed wrote: kenyee wrote: ? Which one did you buy? :? If you bought the one you linked, it won't work because the mount is wrong. If you bought the one I linked to, it should work fine. thank you for replay I bought the one which I link so what can I do now is there any solution or I should replace it with one that you link it to me ? please try to give me other solution instead of replace it thank you again |
