Fri Jun 07, 2013 10:00 pm
I just received my vagabond mini today and a small metal object fell out of it. Is it still safe to use? Here a some photos > http://cl.ly/image/0E0C06450P1a // http://cl.ly/image/0e1h2C0L101G // http://cl.ly/image/0B0A2n1c2M1j
Fri Jun 07, 2013 10:22 pm
I can't identify the object . . . looks like a large blob of solder to me. Certainly not a component of any sort.
My gut opinion is that it is probably safe to use. On the other hand, it's good the solder blob fell out . . . had it stayed in there rolling around it would likely cause a short and a failure. If you prefer, we would be happy replace to the VML. Just write info@paulcbuff.com.
BTW, I have never seen a defect like this . . . most likely the fault of excess solder being applied.
Have you tried to use it? Does it work OK.
Sat Jun 08, 2013 6:15 am
It seems to work okay.
Sat Jun 08, 2013 9:17 pm
Good.
I'll forward this string to customer service so they are aware of your unusual situation.
Users browsing this forum: No registered users and 22 guests
