Sun Jun 23, 2013 3:24 pm
My CyberCommander V40 is turning on - Turns the Einstein all the way up - Rapid Fires - Then Turns off. It does this over and over with no way to stop it. I have taken the batteries out and tried it again. Same result. I take the battery out, turn on the Einstein and the flash operates as normal. It's the Cyber Commander that is causing the issues.
At this point it is unusable. Any thoughts? I take very good care of this and is safely stored when not in use.
Last edited by dmcphotography on Mon Jun 24, 2013 8:20 am, edited 1 time in total.
Sun Jun 23, 2013 8:16 pm
Try removing the SD card. Also, with the light unplugged. Turn the CC on and see if the channel is set for the light to be at full power. If you have multiple lights does this happen with all of them?
Mon Jun 24, 2013 8:17 am
Thank you for the suggestion of taking out the SD card but results are the same. The CC won't stay on long enough to do anything with it. It won't allow me to push any buttons to change settings before it turns itself off.
I have tried 3 sets of different batteries thinking that was the issue. Same result.
Any other thoughts as to what I should do?
Mon Jun 24, 2013 9:05 am
At this point, it sounds like the unit will need to come in for inspection. Information on repair can be found here: http://www.paulcbuff.com/repair.php
Mon Jun 24, 2013 12:04 pm
Thank you. Your quick responses are very impressive.
It has been Shipped Priority Mail to Paul C Buff in Nashville. Thanks.
