Low Voltage Cutoff - VML Battery?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4113
Author:  Sienna [ Sat Aug 03, 2013 11:22 am ]
Post subject:  Low Voltage Cutoff - VML Battery?
Hello,
If I wanted to use the VML's battery for other things, does the battery itself have any low voltage cutoff or other protection options?
Also, does the battery do internal balance charging of the cells?
Thanks,
Caitlyn
Author:  Technical Support [ Mon Aug 05, 2013 12:00 pm ]
Post subject:  Re: Low Voltage Cutoff - VML Battery?
Yes the VML batteries have both, a low voltage cutoff and internal balancing. This, of course, is not an endorsement for any use outside of the VML.
