Sun Aug 04, 2013 5:39 pm
I may be imagining this but it seems like the 25w modeling lamp recommended for use with the Einstein and Vagabond Mini combination is a bit on the red side. This seems to get more pronounced as the wattage is lowered.
Mon Aug 05, 2013 9:20 am
Look reddish as compared to what? The model lamps are incandescent lights, which will be in the neighborhood of 3000K, and will go lower as voltage is reduced.
Mon Aug 05, 2013 10:42 am
Thanks, that explains what is going on; I thought they were supposed to be more towards the daylight range.
Mon Aug 05, 2013 12:04 pm
Generally speaking, model lamps most flash units on the market will be incandescent and have uncorrected color temperature. Even those that do will still shift as voltage is reduced.
