Isolating a channel
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4118
Author:  dlscott56 [ Tue Aug 06, 2013 8:11 pm ]
Post subject:  Isolating a channel
I'm sure this is in the manual somewhere. How do I fire a test shot with just one channel going off so I can see the effect isolated? I know I've done this before but can't seem to find it.
Forgot to mention this is using the CyberSync Commander.
Thanks in advance for your help.
Dave
Author:  Technical Support [ Tue Aug 06, 2013 9:07 pm ]
Post subject:  Re: Isolating a channel
You would need to set the channel up as a group. This is discussed on page 48 in the current manual.
http://www.paulcbuff.com/manuals/cc.pdf
Author:  dlscott56 [ Tue Aug 06, 2013 9:23 pm ]
Ok, so for simplicity sake, I typically use channel 1 for my main light, channel 2 for one or more 'kickers', and channel 3 for the background. If I set each of these up as a separate group and put a marker, maybe taped onto my Einsteins, as to which channel they are currently set for, I should be able to set up my lighting and also have everything set so that I can select to fire an individual group to see what each one looks like?
Author:  Technical Support [ Tue Aug 06, 2013 10:50 pm ]
Yes, if by "fire" you mean triggered by the camera, as opposed to buttons. (The buttons do not require the grouping like the hotshoe does)
Author:  dlscott56 [ Sat Aug 10, 2013 6:58 am ]
Ok, thanks.
