| Vagabond II problems http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4128 |
| Author: | eiand [ Thu Aug 15, 2013 12:49 pm ] |
| Post subject: | Vagabond II problems |
Hi, I´m having some problems with my VB2. I had to buy a new battery, and that worked fine, but when I recharged it with a car battery charger I couldn't connect it anymore because there came a spark and the fuse got blown. I bought a new similar battery (I thought I overcharged it) but the same thing happened to the new battery. Is it the battery, or maybe the inverter that is gone? Or something else? I live in Norway so it´s hard for me to send it in to you guys, and I would hate to buy a new one since I´m low on cash.. Hope someone can help me! |
| Author: | Technical Support [ Thu Aug 15, 2013 4:19 pm ] |
| Post subject: | Re: Vagabond II problems |
If you are continuously blowing fuses when connecting the battery, there is a fault in the inverter. This would require the unit to come in for inspection or repair. Small sparks at the battery terminal when connecting is not a big deal, but if fuses are blowing, that is a more serious matter. |
| Author: | eiand [ Fri Aug 16, 2013 1:53 am ] |
Thank you for the fast reply. I was afraid of that. -Eirik |
