| What amperage extension cord to use with Einsteins? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4141 |
| Author: | robhu [ Sat Aug 24, 2013 10:07 am ] |
| Post subject: | What amperage extension cord to use with Einsteins? |
Hi - Could you please tell me what amperage extension cord I should get to use with an Einstein in the UK (240 volts)? How many amps does the Einstein draw? Thank you, -Rob |
| Author: | Technical Support [ Mon Aug 26, 2013 9:44 am ] |
| Post subject: | Re: What amperage extension cord to use with Einsteins? |
In the U.S. we recommend a 12-14 gauge extension cord. This translates to a 1.63 to 2.05mm diameter wire (or 2.08 to 3.31 sq. mm). Max amperage is 8-9A. |
| Author: | robhu [ Mon Aug 26, 2013 9:49 am ] |
Thank you. |
| Author: | leslieianramos [ Wed Jan 18, 2017 8:42 pm ] |
I have both 12 and 14 50ft long 3-OUTLET extension cables rated at 300v. Is it safe to attach 3 Einsteins on either one? What are the limitations? Cheers! |
| Author: | Technical Support [ Fri Jan 20, 2017 2:23 pm ] |
using either should be fine. If given the choice, go with the bigger cord. There may be some slight reduction in recycle time. |
