Can't turn on the Cyber commander anymore
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4149
Author:  DS-Studio [ Wed Aug 28, 2013 4:14 am ]
Post subject:  Can't turn on the Cyber commander anymore
Hi gents , I have an issue with my CC , i used it while I had the low batteries flashing on the screen and when I pressed a button the CC triggered all the flash like stroboscopes for 2 or 3 seconds and then stoped working , I replaced the batteries , tryed with/out the card , but no help , I can't switch it back on ... :?
Any help or idea would be appreciated .
Author:  Technical Support [ Wed Aug 28, 2013 9:37 am ]
Post subject:  Re: Can't turn on the Cyber commander anymore
With known good batteries, try the unit again without the card. If the unit still does not respond, you can try to reload the firmware (as described here: http://www.paulcbuff.com/fw-cc.php)
If that is not successful, then the unit will need to be serviced.
Author:  DS-Studio [ Fri Aug 30, 2013 9:45 am ]
With some totally brand new batteries it came back to life. :P
I took the opportunity to update the firmware by the same time .
Thanks for the help ;)
