Sun Sep 01, 2013 12:07 pm
I use the CSR+ transmitter and recently purchased the Vagabond II. I tried out the battery with one of my AB400s and the flash will not trigger nor will the test flash go off when using with the CSR+. If I plug the battery directly into the AB or if I use the cable to connect my camera to the flash everything works fine. If I have the CSR+ plugged in with the battery, nothing works. Is the CSR+ compatible with the Vagabond II?
Sun Sep 01, 2013 1:53 pm
It sounds like you may be using the telephone style jack and not using a Cyber Commander. If this is the case, be sure to use the 1/8' to 1/8" cord.
Alternatively, you may not have a cord from the receiver to the light, other than the power cord. Again, be sure you are using the 1/8 to 1/8 cable.
Also, to be sure, you have a transmitter in the hotshoe of the camera and a receiver on the light, correct?
Sun Sep 01, 2013 3:55 pm
Hi,
I didn't even think about trying the other telephone style jack cords. I'll check those and post my results.
Thanks so much for the quick reply.
Diana
Mon Sep 02, 2013 9:59 am
OK, the telephone style cord will not work (properly). You must use the headphone style cord that goes into the round hole.
Also, does this same set up work in a regular wall outlet?
