Wed Aug 28, 2013 4:14 am
Hi gents , I have an issue with my CC , i used it while I had the low batteries flashing on the screen and when I pressed a button the CC triggered all the flash like stroboscopes for 2 or 3 seconds and then stoped working , I replaced the batteries , tryed with/out the card , but no help , I can't switch it back on ... :?
Any help or idea would be appreciated .
Wed Aug 28, 2013 9:37 am
With known good batteries, try the unit again without the card. If the unit still does not respond, you can try to reload the firmware (as described here: http://www.paulcbuff.com/fw-cc.php)
If that is not successful, then the unit will need to be serviced.
Fri Aug 30, 2013 9:45 am
With some totally brand new batteries it came back to life. :P
I took the opportunity to update the firmware by the same time .
Thanks for the help ;)
Users browsing this forum: No registered users and 35 guests
