Einstein powers up, no lamp or flash
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4153
Author:  aaron843 [ Sun Sep 01, 2013 3:11 pm ]
Post subject:  Einstein powers up, no lamp or flash
My Einstein will power up, the fan comes on, and it says it is ready. After tripping a breaker, it won't fire and there is no modeling light. Is it possible that the flash tube and the modeling light are both bad? Is there a good way to test to see if I just need to replace both?
Author:  kenyee [ Sun Sep 01, 2013 5:55 pm ]
Post subject:  Re: Einstein powers up, no lamp or flash
Does the test fire button on the back do anything?
Author:  Technical Support [ Tue Sep 03, 2013 10:16 am ]
This will likely be an internal fault, however, you can look at the model lamp and see if it is bad. Usually the filament is visibly broken when bad. You can also look for visible breaks in the flash tube.
If you have another E640, or have spares, you can swap bulbs to see if the unit will continue to work.
You can order new bulbs to try, but it is unlikely to resolve the problem.
