Cybersync AC receiver
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4161
Author:  Don Kondra [ Thu Sep 05, 2013 10:05 pm ]
Post subject:  Cybersync AC receiver
I notice the receiver does not have a power on/off switch.
With the strobe turned off, does it matter if the power cord is left plugged in for an extended time ?
Cheers, Don
Author:  Technical Support [ Fri Sep 06, 2013 8:50 am ]
Post subject:  Re: Cybersync AC receiver
Generally not. However, if there is a spike in the AC power supply, the unit may lock up. If this happens, unplugging the power cord and letting it sit for a few minutes usually resolves the issue. This lock up is usually characterized by a solid red/amber LED.
Author:  Don Kondra [ Fri Sep 06, 2013 9:15 am ]
Thank you !
Cheers, Don
