Vagabond Mini threaded socket problem
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4206
Author:  rdalrt [ Mon Oct 14, 2013 2:21 pm ]
Post subject:  Vagabond Mini threaded socket problem
I have a small problem with my VML. I threaded a super clamp into the socket on the bottom to mount it on a pole. But now the brass fitting from the super clamp won't unthread. It seems the whole socket in the VML is turning. Guess maybe I tightened it too much.
Any suggestions on how to get the fitting unthreaded?
Thanks.
Author:  Technical Support [ Mon Oct 14, 2013 4:36 pm ]
Post subject:  Re: Vagabond Mini threaded socket problem
It sounds like the spigot was over tightened. This is something that can be repaired, thought it will need to come in. I would contact our repair department to get a cost estimate.
