Cybsersync CSRB Not sending signal via cable test light work
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4210
Author:  artiisan [ Tue Oct 15, 2013 2:22 am ]
Post subject:  Cybsersync CSRB Not sending signal via cable test light work
To further investigate the situation I have taken it apart to see if any solders have broken loose , to find nothing. I am really at a loss any help would be great, Thanks in advance.
Author:  Technical Support [ Tue Oct 15, 2013 10:05 am ]
Post subject:  Re: Cybsersync CSRB Not sending signal via cable test light
With the receiver connected to the light, and the light and receiver on do the following:
Press the gray test button on the receiver. Does the flash fire?
Remove the cord from the receiver. Does the flash fire as you remove the cord?
Remove the cord from the light. Does the flash fire as you remove the cord?
Press the red test button on the flash unit. Does the flash fire?
Author:  artiisan [ Wed Oct 16, 2013 2:18 pm ]
No the flash hasn't fired,yes it fires when I remove the cord as well I have tested it on my hotshoe mount. Yes the flash unit test button does fire
Author:  Technical Support [ Thu Oct 17, 2013 9:19 am ]
It fires when you remove the cord from where?
If it fires when you remove it from the light, but not when you remove it from the receiver, you probably have a faulty cord.
If it fires when you remove it from the receiver, but not from the receiver's test button, then the problem is in the receiver. This would require warranty service or replacement (depending on warranty status).
