 [ 1 post ]
Mon Oct 28, 2013 9:45 am
Just a quick little note on an on-going issue I've been having with one of my Einsteins. When I would fire the flash unit at a faster than my normal pace(say every 3 seconds) I noticed a burning smell. At first, when it was new, I shrugged it off as just a burn in phase. So the other day I took my units out to start a project and noticed one was still burning. I took the dome off and found one of the rubber insulators was cooking under the heat of the flash tube. I pulled the tube out, compared it with the non-burnt tube from other Einstein, and made the adjustment.
If you try this, be warned not to cut it too far down or it will become unusable. Here is image.
RMS
 [ 1 post ]
