| Sekonic L-478-DR light meter and MC-2 http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4232 |
| Author: | DIPHOTO [ Tue Oct 29, 2013 1:58 pm ] |
| Post subject: | Sekonic L-478-DR light meter and MC-2 |
Is anyone having triggering issues when using the L-478-DR light meter with the MC-2 receivers? I've updated the firmware on everything but the triggering is not consistent. I'll get two positive triggers then no trigger. |
| Author: | Technical Support [ Thu Oct 31, 2013 2:39 pm ] |
| Post subject: | Re: Sekonic L-478-DR light meter and MC-2 |
Unfortunately, this is likely rooted in the flashmeter radio. We do not have any information on this. |
| Author: | TimHenrion [ Tue Nov 05, 2013 2:49 pm ] |
DIPHOTO wrote: Is anyone having triggering issues when using the L-478-DR light meter with the MC-2 receivers? I've updated the firmware on everything but the triggering is not consistent. I'll get two positive triggers then no trigger. I did a shoot a few weeks ago with the L-478DR and two Einsteins with PowerMC2's. Worked flawlessly. The only thing that you have to keep in mind is that you have to decide *where* you want to control the flash power from (the PocketWizard transmitter on your camera *OR* the L-478DR). You can't have two things controlling the flash power at the same time. I wanted the meter to control the power (with the nifty on-screen sliders) so I had to go into the PocketWizard Utility and set "No Change (Trigger Only)" in the SPEEDLIGHT section on my transmitting TT5. Lots of L-478DR information in the PocketWizard wiki: http://wiki.pocketwizard.com/index.php? ... ic_L-478DR |
