Sat Nov 09, 2013 11:14 am
after buying CC ($1.1000) it continues to shut down and crash. wipes out all groups,and settings just replaced battery's and all it does now is turn it self on and off over and over again. not happy and need solutions please. :twisted: :twisted: :twisted:
Sat Nov 09, 2013 12:23 pm
Try removing the microSD to see if the problem persists.
Sat Nov 09, 2013 1:49 pm
ok i removed the card and put it back in and all is good for now. THANKS! i'll keep you posted!
clint
Sat Nov 09, 2013 6:43 pm
Ok, That means the card is likely corrupted from an initial power loss from low batteries. If you have saved setups on the card, you can back those up to the computer. They can be found in the SD drive: PCBUFF>CCMDR>CONFIGS.
Once any existing setups are backed up, the card can be reformatted to FAT16. FAT32 (FAT on a Mac) or exFAT is not compatible. Once reformatted to FAT16, the card should be able to be reinstalled with no issues.
