Mon Nov 11, 2013 2:47 pm
I have an AB1600 with pocket wizard TT5. I use the sekonic L478dr to a just the power of the strobe in conjunction with the AC9.Everything works normal except the sekonic won't set the power the the lowest point. If I unplug the tt5 and push the power slider all the way down the power will then go to its lowest setting. Any idea why this might be?
Thanks.
Tue Nov 12, 2013 12:14 am
Is the power slider set to the far right when attempting to make this adjustment?
What exactly happens when you try this? In other words, how low does the light get?
Tue Nov 12, 2013 12:20 am
I figured it out. I had the power slider set at 1/8 and then when I turned everything on the sekonic was using the 1/8 as the lowest power. I just put the slider all the way to the left and then turned everything on and its working fine.
Users browsing this forum: No registered users and 41 guests
