Fri Nov 22, 2013 9:42 am
A little info. - I have 2 WL Ultra 1800’s 1 has bad tubes in it. I want to start taking in studio portrait photos. The area where I will be taking these is to small to use the 1800's even at the lowest setting.
I know that I should buy a couple of smaller strobes but that is not an option at this time.
I put 1 of the good tubes in the head with the bad tubes in order to verify that the tubes where in fact the problem, which was the case. I set up my lights the way i wanted and noticed that with 1 tube in each head I was able to get the lighting that I need.
My question is, am I going to hurt the 1800's by using them with only 1 good tube?
Thank you in advance for any help.
Fri Nov 22, 2013 1:28 pm
You should not have any problems with short term usage. Long term, if you only used one side, would cause the other side (by which I mean one of two banks of flash capacitors) to deteriorate from disuse.
Fri Nov 22, 2013 2:39 pm
So I will just have to remember to switch the tubes around every now and then.
Thank you, I feel better now.
Users browsing this forum: Majestic-12 [Bot] and 26 guests
