Thu Nov 28, 2013 1:57 am
Please tell me on a diagnostic panel shows the actual voltage on the capacitors?
For this line, you can diagnose the problem of the converter, which charges the capacitors?
After a sudden power outage E-640 has ceased to flash, but the rest of the system working properly.
Thank you.
Sat Nov 30, 2013 8:37 am
The cap voltage line tells you what the the voltage to which the capacitors are charged. This will vary based on the current power setting. I doubt this will tell you anything useful to diagnose the flash unit. If the unit is not firing, you can try changing flash tubes, though I doubt that is the problem. Otherwise, it should be sent in for repair.
Sat Nov 30, 2013 12:58 pm
Thanks for the answer.
Flash shipped to the dealer service center to carry out diagnosis and repair.
