| Diagnostics Screen - Cap Voltage http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4264 |
| Author: | iTuner [ Thu Nov 28, 2013 1:57 am ] |
| Post subject: | Diagnostics Screen - Cap Voltage |
Please tell me on a diagnostic panel shows the actual voltage on the capacitors? For this line, you can diagnose the problem of the converter, which charges the capacitors? After a sudden power outage E-640 has ceased to flash, but the rest of the system working properly. Thank you. |
| Author: | Technical Support [ Sat Nov 30, 2013 8:37 am ] |
| Post subject: | Re: Diagnostics Screen - Cap Voltage |
The cap voltage line tells you what the the voltage to which the capacitors are charged. This will vary based on the current power setting. I doubt this will tell you anything useful to diagnose the flash unit. If the unit is not firing, you can try changing flash tubes, though I doubt that is the problem. Otherwise, it should be sent in for repair. |
| Author: | iTuner [ Sat Nov 30, 2013 12:58 pm ] |
Thanks for the answer. Flash shipped to the dealer service center to carry out diagnosis and repair. |
