 [ 1 post ]
Fri Dec 13, 2013 9:02 am
I found that adjusting the light stand pivot mount of a E640 with a large modifier can challenge gravity.
As long as you are using a softbox and not an umbrella you can put a nice looking screw driver in the umbrella slot so that the handle is at the back of the E640. It gives you just enough leverage to make adjustments to the mount.
(IMPORTANT - you must use a nice looking screw driver with a black handle... it has to look cool, or you just have a screwdriver stuck in your light)
 [ 1 post ]
Users browsing this forum: No registered users and 26 guests
