| Padded bag for VML while in use? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4289 |
| Author: | TomMeyer [ Fri Dec 13, 2013 9:33 am ] |
| Post subject: | Padded bag for VML while in use? |
I'd like to keep my VML (2 of them) in a small padded bag, hanging on the light stand while they are in use (Einsteins). I've been using a Think Tank lens bag that fits perfectly, not tight, but snug. After a two hour shoot (540 pops at 1/8th power), it felt a little warm. Not hot, but probably about 100 or 105 degrees F. Is this bad for the battery/inverter? Should I look for a different way to hang it from a stand? (not crazy about the provided clamp) Thanks, loving my new PCB lighting system. |
| Author: | Technical Support [ Fri Dec 13, 2013 10:38 am ] |
| Post subject: | Re: Padded bag for VML while in use? |
No. Do not run the VMLs while enclosed in a bag. From page 2 of the VML manual: WARNING! Do not operate or charge the Vagabond Mini™ Lithium system inside a carry bag or backpack. Air circulation around the Vagabond Mini™ Lithium system and charger must be provided. Do not obstruct the Vagabond Mini™ Lithium system’s internal fan or ventilation holes during use or when charging. If you let the VML rest on a knuckle or yoke on the light stand, it will be supported by the included clip. You can also hang the VML from the stand by the carry strap. |
| Author: | TomMeyer [ Fri Dec 13, 2013 11:57 am ] |
Thanks... t |
