Mounting PCB softboxes to Dynalite
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4293
Author:  shampoo [ Mon Dec 16, 2013 3:17 pm ]
Post subject:  Mounting PCB softboxes to Dynalite
Hi
Is there a speedring or adapter ring I can pick up that will allow me to put my PCB softboxes onto a Dynalite head ?
J
Author:  Technical Support [ Mon Dec 16, 2013 4:59 pm ]
Post subject:  Re: Mounting PCB softboxes to Dynalite
http://www.bhphotovideo.com/c/product/2 ... _Ring.html
The illuminata speedrings I have tried in the past fit our softboxes. I have not tried this one, so.... cannot guarantee it will work, but I see no reason that it won't.
Author:  shampoo [ Mon Dec 16, 2013 5:14 pm ]
Technical Support wrote:
http://www.bhphotovideo.com/c/product/277148-REG/Photek_MCAR_06_Illuminata_Insert_Adapter_Ring.html
That's even better then what I had hoped!
I can just pop in or out this insert when I need to mix and match. That means I can keep using and buying more PCB softboxes as needed.
Perfect!
J
Author:  eadams [ Mon Sep 15, 2014 8:42 pm ]
For what it's worth, I purchased the above speed ring at your recommendation. Indeed, the speed ring linked above works perfectly for me with my Dynalites. I'm using it with an extra large softbox and the fitting is quite solid.
- Eric
