| Flash hot, modeling light low, how to get focus? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4303 |
| Author: | jenniferljl [ Fri Dec 20, 2013 2:35 am ] |
| Post subject: | Flash hot, modeling light low, how to get focus? |
I realize this isn't a question about my AlienBees B400, but how to use it. I want to shoot at f2.8 so I put an ND filter on my lens, which helped bring the hot spots down a lot. However, even at the very lowest setting at ISO 100 I can't quite get what I'm looking for. The biggest problem I'm having is that the modeling lamp gets so low at the same time that I can't get enough contrast on my subject (shooting through the ND filter) to focus on the spot (the eye) that I want to focus on. Do I just need to turn on a bank of LED light to achieve focus, then keep my shutter high enough to rule out the ambient? I'm getting dizzy, juggling all the factors and a moving subject. :-) |
| Author: | Technical Support [ Fri Dec 20, 2013 10:06 am ] |
| Post subject: | Re: Flash hot, modeling light low, how to get focus? |
If you press the the button on the back of the light marked TRACK, it should pop out and return the model lamp to full power. |
| Author: | jenniferljl [ Fri Dec 20, 2013 9:12 pm ] |
YAY! Thank you! Much appreciated. :-) |
