| B400, B800 or B1600 flash unit ??? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4320 |
| Author: | urbana [ Wed Jan 08, 2014 4:04 pm ] |
| Post subject: | B400, B800 or B1600 flash unit ??? |
Hello I'm about to purchase flash unit,but can't decide If I should go with B400 B800 or B1600. What's the difference between all of them? I'd really appreciate any information. Thank you! |
| Author: | Technical Support [ Wed Jan 08, 2014 6:10 pm ] |
| Post subject: | Re: B400, B800 or B1600 flash unit ??? |
Power. The B1600 is one stop more powerful than the B800, which is one stop more powerful than the B400. Flash duration will be affected by the increase of power, in that it gets shorter as you move up in flash model. B800 is our most popular light as it is a good all around flash. If you need a lot of power, like shooting outside in bright sun, then the B1600 may be better. If you are wanting to mix with interior ambient lighting, the B400 may be a better fit, as it can go lower than the others. If a broad range of power adjustment is required or desired (i.e. you shoot in dim light today, and groups on the beach tomorrow), then you may consider an Einstein640. http://www.paulcbuff.com/e640.php |
| Author: | urbana [ Wed Jan 08, 2014 7:34 pm ] |
Thank you so much!!! I'm setting up a studio at home. I have only natural light (huge windows) - no ambient. I'm going to photograph newborns and children and family. Would B800 be my best fit then? Also, should I purchase a softbox too? Thank you, Anna Technical Support wrote: Power. The B1600 is one stop more powerful than the B800, which is one stop more powerful than the B400. Flash duration will be affected by the increase of power, in that it gets shorter as you move up in flash model.
| Author: | Technical Support [ Thu Jan 09, 2014 10:05 am ] |
urbana wrote: I have only natural light (huge windows) - no ambient. "Ambient" light is light that is already there, be it natural or artificial. Light coming in through a window would also be ambient light you could use along with a studio flash. If you wanted to use the natural light, I would say go with the B400. Otherwise, the B800 would be a better choice. You will definitely need a modifier, and softboxes are a very popular choice, often purchased with a grid. I would suggest a 32x40 as an all around. Alternatively, you go with our PLM system which mimics octaboxes very similarly, except you cannot grid them (though some configurations would not require grids). For your uses, I would suggest a 51" or 64" soft silver, 8mm style with a white front diffusion fabric. They are smaller, lighter, less expensive and easier to manage. |
| Author: | urbana [ Mon Jan 13, 2014 3:21 pm ] |
To properly light my studio and subjects (I'm thinking up to 5,6 people), how many flash units do I need and what power should they all be? Thank you so much for all the information, it truly helps! Technical Support wrote: urbana wrote: I have only natural light (huge windows) - no ambient. "Ambient" light is light that is already there, be it natural or artificial. Light coming in through a window would also be ambient light you could use along with a studio flash. If you wanted to use the natural light, I would say go with the B400. Otherwise, the B800 would be a better choice. You will definitely need a modifier, and softboxes are a very popular choice, often purchased with a grid. I would suggest a 32x40 as an all around. Alternatively, you go with our PLM system which mimics octaboxes very similarly, except you cannot grid them (though some configurations would not require grids). For your uses, I would suggest a 51" or 64" soft silver, 8mm style with a white front diffusion fabric. They are smaller, lighter, less expensive and easier to manage. |
| Author: | Technical Support [ Mon Jan 13, 2014 5:56 pm ] |
Ask 100 people, you will get 100 different answers, all of which are equally correct. I would do 2 B800's and, optionally, a B400 or 800 as a third light. It will rarely be at full, but it can be if you need it to. One light will be main, one for fill, and one as a back ground light. Two 64" soft silver 8mm PLM's with white front diffusion fabrics will make for a very versatile set up. Add in a 20-30 degree grid for background light or hair/rim light. |
