| lowering the power of all the strobes at once... http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4332 |
| Author: | victorwol [ Thu Jan 23, 2014 4:10 pm ] |
| Post subject: | lowering the power of all the strobes at once... |
Hi! Is it possible to lower the power of all the Einsteins I have at the same time with the cybercomander ??? Thanks |
| Author: | Technical Support [ Thu Jan 23, 2014 4:35 pm ] |
| Post subject: | Re: lowering the power of all the strobes at once... |
Yes. In the main flash screen, use the left joystick to scroll to the ALL channel setting. You can then lower (or raise) all lights in ratio. You can raise or lower until one light reaches maximum or minimum power. At that point, no more adjustment is allowed, unless you go to an individual light or group that does not contain a light that is at max/min. If you have a light programmed in stand by, it will raise or lower along with the other lights. If this light goes to max or min, this will stop the other lights from increasing or decreasing. |
