| Vegabond mini http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4352 |
| Author: | DBiasPhotography [ Tue Feb 11, 2014 2:57 pm ] |
| Post subject: | Vegabond mini |
I have a mini that I got last year summer time. It has worked fine until a shoot I did Sunday. Plugged a light in,and no power. The mini comes on and shows that the battery is fully charged. So,I checked wit my other lights and still nothing. No power going to the lights. Checked the fuse,fuse is good also. Can someone maybe give me some insight as to what the issue may be? Thanks |
| Author: | Technical Support [ Tue Feb 11, 2014 6:01 pm ] |
| Post subject: | Re: Vegabond mini |
Try reseating the battery. It could be that it jostled loose enough to lose contact between battery and inverter. Also try both outlets. It is possible to lose one outlet and not the other. Do you get a green LED next to the USB port? That is your actual "ON" light for the inverter. |
