Wed Feb 19, 2014 11:57 am
Below is what I now own. What is the proper way to equalize the modeling lights with the Cyber Commander for best WYSIWYG use?
Code: Select all
Einstein E640     640ws       250w,supplied
WL Ultra 1200     600ws       250w,BBA1
WL Ultra 600      300ws       250w,BBA1
Also, the WL Ultra instructions mention the "relative model switch" as follows:
Ultra setting: 0 = 500w, -1 = 300w, -2 = 150w
Does that mean you can output 500w or 300w from a 250w bulb and never the rated 250w?
Wed Feb 19, 2014 3:37 pm
Well, at "0" the BBA1 bulb is consuming 250W. However, with the way the bulb is designed, it emits a similar amount of light as a 500W bulb normally (it is essentially a 60VAC filament running on 120VAC). This is why they have such a short life when running at full power.
The way I would suggest setting up your lights would be to set the E640 to full, the U1200 to -1 and the U600's at -2 (assuming you are using BBA1's).
If you use normal 250W bulbs, then use 0 on the 1200 and -1 on the 600's.
Fri Feb 21, 2014 1:51 am
Ok, I'll give it some thought and a try! thanks..
Fri Feb 21, 2014 1:41 pm
Also, it is worth noting. Wattage is not a measurement of light output. It is a measurement, in this case, of power consumption. So the BBA1 is still consuming 250W, but it is brighter than a regular halogen bulb which also is consuming 250W.
Lumens would be the measurement used for light output.
