Wed Feb 26, 2014 3:41 am
I have a canon EOS 60D that does not have a PC sync terminal. I want to have an on camera TTL flash (e.g. 580EX II) and also trigger one of paul c buff's monolights (white lightnings or alienbees), is it possible with the cybersync?
If I mount the cybersync transmitter on the hotshoe, then there is no place to mount the canon flash. If I mount the canon flash on the hotshoe, then I cannot mount the cybersync. Any ideas?
Wed Feb 26, 2014 10:18 am
This adapter is a pass through TTL hot shoe and a PC terminal. Slide this into the hotshoe, the flash into it, and plug the CST into the PC port.
http://flashzebra.com/products/0268/index.shtml
Do keep in mind TTL flash and manual flash don't like to play nice together. It can work in some cases, but you will likely overexpose in most cases without some intervention on your part.
Users browsing this forum: No registered users and 30 guests
