Thu Mar 06, 2014 3:27 pm
hi,
I have a problem with my vagabon mini 230VAC
please look the video on youtube :
http://youtu.be/Y8cIxEV33DM
Have you an idea of ​​the problem? do I send it for repair?
thanks
Fri Mar 07, 2014 5:05 pm
Remove the battery and plug in the VMC3A charger into the inverter. Switch ON the inverter and if it reacts the same way then the inverter is most likely the culprit. It will have to come back for repair.
Fri Mar 07, 2014 9:38 pm
Hi,
it's exactly the same thing. and the charger flashes too.
what is the return process for repair?
cordially
Mon Mar 10, 2014 12:04 pm
Being that you are overseas, and this is a lithium battery, I would recommend contacting Customer Service to see what the best method is for getting this unit back to us. They can be reached at info@paulcbuff.com.
Users browsing this forum: No registered users and 4 guests
