Sat Mar 01, 2014 6:44 am
Hi - I have just bought 2 Einsteins 640 from a Friend of mine (since deceased.. so cannot ask him) one of them the fan is on all the time, the other it is not. None of documentation I have found tells me if this is ok. Do the fans work all the time ... and therefore I have an issues with one, or do they turn on when needed?
Only testing them at the moment and no model lamps on - any advice on what I should do please? I do not want to break the one without the fan running ...
Thanks a lot in advance - a Paul Buff novice :?
Peter
Sat Mar 01, 2014 9:39 am
Peter
As I recall, the Einstein fan used to run all the time. This was changed in one of the firmware updates such that the fan only comes on when the unit reaches some temperature threshold. Take a look at the firmware versions to see if they're the same. Updates can be downloaded from the Buff website.
Sun Mar 02, 2014 12:32 am
I assume, like BIC, that the Firmware might be different: Version 29 changed the fan function, as to only run, when needed. See here:
http://www.paulcbuff.com/fw-e640-history.php
Mon Mar 03, 2014 10:22 am
Yes the E640 fan is constant once the unit is switched ON. However, from FW29 to present the fan is constant with variable speeds based temperature.
Users browsing this forum: Majestic-12 [Bot] and 20 guests
