| Elinchrom Rotalux Softboxes on the Einstein Flash Unit? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4379 |
| Author: | einsteinnewb [ Tue Mar 04, 2014 10:36 am ] |
| Post subject: | Elinchrom Rotalux Softboxes on the Einstein Flash Unit? |
Hey, Can I use my Elinchrom Rotalux Softboxes also on my Einstein Flashes? If yes what i need? Thanks |
| Author: | likwidplastik [ Tue Mar 04, 2014 1:54 pm ] |
| Post subject: | Re: Elinchrom Rotalux Softboxes on the Einstein Flash Unit? |
einsteinnewb wrote: Hey, Can I use my Elinchrom Rotalux Softboxes also on my Einstein Flashes? If yes what i need? Thanks Elinchrom makes a Rotalux speedring for Alien Bees. That's all you need. Here's a link: http://www.bhphotovideo.com/bnh/control ... &A=details |
| Author: | tetrode [ Thu Mar 06, 2014 9:32 pm ] |
Assuming the Elinchrom Rotalux AB rings haven't been redesigned since I got mine, be warned that they do not mate with the Einstein's mounting fingers well at all. While most AB speed ring inserts have a dished profile, the Elinchrom AB ring has a stepped profile. The vertical side of the step prevents the light's mounting fingers from opening fully: ![]() This is as far as the accessory locking lever on the Einstein can travel: ![]() The mounting fingers are not locked with the lever half way up the slot. This is a *very* surprising design blunder on the part of Elinchrom. |
