All einsteins fire at once when only 1 is selected
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4398
Author:  fstop [ Sat Mar 15, 2014 7:28 am ]
Post subject:  All einsteins fire at once when only 1 is selected
I’ve got a cyber commander & 3 Einstein’s. When I go to meter the light on 1 of the Einstein’s I select channel 1 for example they all go off. It does not matter what channel I select they all go off. How can I fix this? I just one to meter one light at a time.
Never mind I just saw the slave cell was on.
Author:  Technical Support [ Mon Mar 17, 2014 9:04 am ]
Post subject:  Re: All einsteins fire at once when only 1 is selected
Make sure when you switch the slave cell off, you do so via the Cyber Commander. Otherwise, the settings will be refreshed, and the slave cells will turn back on.
