Tue Mar 11, 2014 10:30 pm
Hi there,
My cyber commander's battery clip is currently broken. Can I order a replacement for this?
I'm not sure if other users of cyber commander had this issue, If I leave the battery in the unit it does drain the "AAA"'s in a day or two. I wish there would have been a hard power ON/OFF switch on these wonderful units.
Please advice! Thanks!
Wed Mar 12, 2014 9:13 am
If you mean the battery door cover, then yes, we can get you a replacement (contact Customer Service). If you mean a metal battery terminal, then that will need to come in for repair.
As for the battery drain, and the battery terminal is not the problem you are referring to, then a firmware update will correct the battery drain issue. Currently, the update will lose the factory meter calibration, however, we are working on correcting that as well.
Tue Mar 18, 2014 8:49 pm
Thank you! Will be in touch with you guys! Can't wait for the new firmware update.
Users browsing this forum: Google [Bot] and 6 guests
