Wed Apr 09, 2014 12:29 pm
Somehow in my case, the 20 degree grid on the back of the snoot got dented and the honeycomb is a bit smashed on one area.
Is that part available, or is there a way to flatten it out again?
Tia.
Mack
Wed Apr 09, 2014 12:56 pm
Depending on the dent size and location, it may not matter much. I would test it to see how it affects the light pattern.
If it does, we may have a salvaged one here. I doubt it, but it is possible. Contact Customer Service to see if they have any.
Otherwise (and I have not tested this myself), you can place a round 20 degree grid in the UMF. I imagine this to be very similar, if not identical. You can also swap out for different grids for different effects.
