Vagabon Mini 220V surge ??
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4420
Author:  teikidev [ Thu Apr 17, 2014 5:52 pm ]
Post subject:  Vagabon Mini 220V surge ??
Hi,
i got a problem with my VM.
I can start it. All the green leds are OK.
But when i plug my Einstein640, with the OEM wire, the einstein doesn't start.
I can only start it if i add an adaptator between to VM and the OEM wire.
Once the Einstein started, i can't get the green "ready" on the LCD panel, and i can't pop the flash.
On the adaptator between the VM and the OEM wire, there are leds. One of those indicate a "surge" error.
Any suggestion ?
Thank you,
Teiki.
Author:  Technical Support [ Wed Apr 23, 2014 12:11 pm ]
Post subject:  Re: Vagabon Mini 220V surge ??
It is likely a fault in the battery pack itself.
Do you have another battery pack to swap into the unit to see if the problem persists?
Do you have a different flash to try?
Does the adapter allow the light to work properly?
I think the "surge" indicator is not abnormal, as the recycle power draw of the light can be rather high and sudden, and is often confused as a surge by monitoring devices. This does not mean there is not a problem, but this is probably not an indicator.
