| Vagabond battery life? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4427 |
| Author: | jzucker [ Fri Apr 25, 2014 8:34 am ] |
| Post subject: | Vagabond battery life? |
My vagabonds are about 2 years old. They have seen reasonable use but wondering if there is a specific time I should look to replace the batteries? |
| Author: | Technical Support [ Fri Apr 25, 2014 8:59 am ] |
| Post subject: | Re: Vagabond battery life? |
If it is the Vagabond Mini Lithium, then you can expect to replace the batteries anywhere between 1-3 years, depending on usage. |
| Author: | jzucker [ Fri Apr 25, 2014 10:38 am ] |
Technical Support wrote: If it is the Vagabond Mini Lithium, then you can expect to replace the batteries anywhere between 1-3 years, depending on usage. yes it is, thanks. I'm guessing I can get through 'til winter before replacing mine. When it fails is it a gradual or steep drop off in charge holding capacity? |
| Author: | Technical Support [ Fri Apr 25, 2014 4:31 pm ] |
First, for the purposes of "shelf life", "end of life" would be defined as a 30% reduction is capacity vs a new battery. This would be a gradual reduction in capacity. |
| Author: | Luap [ Sat Apr 26, 2014 12:51 am ] |
We don't have exact data on this, because it takes three years of testing to find out. Haven't had a whole lot of battery replacements yet, so it looks like the majority are lasting over three years. I suspect after falling to 70% they will start dropping at an accelerated rate. |
