| White Lighting Ultra Sync Cable http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4443 |
| Author: | Leftboot [ Thu May 15, 2014 3:42 am ] |
| Post subject: | White Lighting Ultra Sync Cable |
I am using the Ultras and need a sync cable for them yesterday sorta thing. (Stepping on them doesn't help. :shock: ) I have been using the "TRS" 1/4 cable but wondering why that is needed. The strobes seem to fire with out problem if I put a headphone adapter on my Alien Bee cable, but don't want to risk damage. If I require, is there somewhere I can get a very short one? (In Canada or on-line.) Thank-you, Ryan |
| Author: | Technical Support [ Thu May 15, 2014 11:51 am ] |
| Post subject: | Re: White Lighting Ultra Sync Cable |
Is this remote to flash or camera to flash? Either way, if what you are using is working, then you should be fine. If you are using a mono cord, there could be some sporadic triggering if you are using a less-than-ideal power source, but this is pretty rare. |
| Author: | Leftboot [ Thu May 15, 2014 12:04 pm ] |
Technical Support wrote: Is this remote to flash or camera to flash? Either way, if what you are using is working, then you should be fine. If you are using a mono cord, there could be some sporadic triggering if you are using a less-than-ideal power source, but this is pretty rare. This is from Yongnuo triggers to the flash. (Thus why I don't want long ones.) I have been using the "proper" cable and just wrecked the last one. Can you explain why the TRS (stereo) cable is required? Is it grounding? |
| Author: | Technical Support [ Thu May 15, 2014 4:45 pm ] |
The ring (the segment furthest from the tip) is unwired and isolates the sync circuit from case ground, which would be a problem if the power supply is miswired in certain ways. |
| Author: | Leftboot [ Thu May 15, 2014 5:07 pm ] |
Perfect, thank-you! Now when will y'al get short versions of the cable?! :) |
| Author: | Technical Support [ Fri May 16, 2014 10:25 am ] |
The mono versions we sell work fine. I cannot honestly say that I have ever seen a problem using the mono cables due to them being mono. |
