vml mini charger blinking green
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4463
Author:  alp [ Mon May 26, 2014 11:54 am ]
Post subject:  vml mini charger blinking green
Two VMLs, less than a year old. Two VML chargers of the same age. I plugged both VMAs in to charge on separate chargers and one charger started blinking, dimly, green, indicating that the battery on that VML was fully charged. Switched chargers and the second charger indicated charging. The first charger went to blinking green on the second VML. A diagram:
VML1 <-> C1 blinking green
VML2 <-> C2 red
VML1 <-> C2 red
VML2 <-> C1 blinking green
Are the chargers that sensitive to the battery levels or is there a problem with that charger?
Author:  Technical Support [ Tue May 27, 2014 2:09 pm ]
Post subject:  Re: vml mini charger blinking green
With known depleted batteries, does the one charger immediately start to blink green? Or does it start to blink green after some time?
Does the red charger ever switch to green?
A blinking green or solid green charger LED is an indicator of a full charge (or a charge considered complete by the charger). If the charger never goes red on a known depleted battery, then there is a problem.
Author:  alp [ Wed May 28, 2014 7:31 pm ]
OK, depleted batteries and both chargers are behaving as expected. One charger must have a more sensitive "full" indicator.
