| flash only fizzles when fired, no ready light. http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4470 |
| Author: | captfish93 [ Sun Jun 08, 2014 11:24 am ] |
| Post subject: | flash only fizzles when fired, no ready light. |
I just started using my equipment again, but when I turned on My 1600, it would not fire, just kind of fizzled. the modeling light doesn't come on either. Any suggestions? |
| Author: | Technical Support [ Mon Jun 09, 2014 11:34 am ] |
| Post subject: | Re: flash only fizzles when fired, no ready light. |
Please clarify "fizzled". Is this a sound it makes, or did you get a low power flash? Or what exactly does that mean? Do you get a green ready light? Also, for the model lamp, turn off (pop out) the Cycle button, and turn on the ON button. Any change? Does a known working bulb work in this socket? |
| Author: | captfish93 [ Tue Jun 10, 2014 11:09 pm ] |
I test fire the strobe and a few small "sparks" that aren't strong enough to light anything fizzle. I'll check the modeling lamp. |
| Author: | Technical Support [ Wed Jun 11, 2014 10:21 am ] |
Are you getting a green ready light on the back of the light? Do you have a telephone cord plugged into the back of the light in the REMOTE jack (i.e. from an LG4X remote or CSR+ remote)? If so, unplug it and see if the problem persists. |
| Author: | captfish93 [ Wed Jun 11, 2014 7:44 pm ] |
Technical Support wrote: Are you getting a green ready light on the back of the light? Do you have a telephone cord plugged into the back of the light in the REMOTE jack (i.e. from an LG4X remote or CSR+ remote)? If so, unplug it and see if the problem persists. I do not get a ready light at all. Even going down to 1/32, nothing. The remote cord is not plugged in either. |
| Author: | Technical Support [ Thu Jun 12, 2014 9:06 am ] |
No ready light means the unit is not charging like it is supposed to. This means the light will need to come in for repair. Please visit this link for repair information: http://www.paulcbuff.com/repair.php |
