Wed Jun 18, 2014 7:34 am
hi,
im thinking of buying a einstein e640, and would like to mount a Profoto 150cm Octagonal modifier.
http://www.wexphotographic.com/buy-prof ... wwodta0avw
Would i be able to put the this modifier on the einstein e640? would i need a converter ring?
Sorry im new to strobes.
Or is there many other octabank that any one can recommend that will work well with the einstein e640?
many thanks
Wed Jun 18, 2014 9:04 am
Most softboxes/octaboxes can be made to fit, if you use the proper speedring. I am not sure if the Profoto stuff uses a standard speedring or not, and if not, do they make one for Paul C. Buff equipment.
We make easy open softboxes, though we do not have a 60 inch octabox. We also have our PLM system, which can very closely mimic the effect of a large softbox. http://www.paulcbuff.com/plm.php
If you need to purchase a speedring, make sure it is compatible with Paul C Buff, Alien Bees, White Lightning, Balcar, or Einstein. These are all the same mount, though different manufacturers use different brands as their descriptor.
****Update, yes, that softbox will fit other brands with the right speedring. I now recall Creative Light was a Profoto brand, and if I recall correctly, the speedring was a little more rounded than others, and it was not (in my opinion) the ideal shape. The outer diameter should be the same size as standard speedrings (including ours), so others should work. Please keep in mind, we have not specifically tested these items, but there should be no issue.
Wed Jun 18, 2014 9:23 am
thank you for you reply
other options im looking for octagonal softbox is
Elinchrom 69 will this fit?
Also i live in UK can i ship my einstein 650 to the UK?
Wed Jun 18, 2014 12:07 pm
We do not ship internationally (aside from Canada). For more information on our international sales policy, please visit this link: http://www.paulcbuff.com/faq.php#international
Users browsing this forum: No registered users and 52 guests
