Wed Jun 18, 2014 9:53 am
Hi --
I just took my Einstein, omni, CSXCV and CST out of the box. They synced no problem and the flash fires when I take a picture. However, every image I take with the flash firing has a visible line across the image which divides it into a dark and light part???? This happens even when I fire my camera completely in the opposite direction to the flash. When I turn the flash off and take a picture, the image is normal. Can you please help!!
Lynne
Wed Jun 18, 2014 11:39 am
Hi Lynne
It's probably a problem with the shutter speed on your camera set too fast. Test it with slower speeds.
Wed Jun 18, 2014 12:16 pm
Yes, most likely a sync speed issue. Most cameras are only capable of syncing at 1/160 to 1/250s or slower (varies by model). Set your camera to 1/160 and retry. You can slowly increase the shutter speed until you see the black band. This will be your maximum sync speed.
Some wireless remotes can/will introduce a significant delay, and push this speed even lower, especially with low batteries. A hard sync cable and CyberSync remotes will trigger fast enough to enable the maximum sync speed possible.
Users browsing this forum: No registered users and 49 guests
