| Einstein not firing with Vagabond Mini http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4493 |
| Author: | pepe88 [ Tue Jul 08, 2014 11:29 pm ] |
| Post subject: | Einstein not firing with Vagabond Mini |
The light will only fire a few times and then it won't. The ready light turns red when the unit is triggered, but the flash doesn't actually fire. Any ideas? The VM works just fine with my White Lightning. |
| Author: | Technical Support [ Wed Jul 09, 2014 9:30 am ] |
| Post subject: | Re: Einstein not firing with Vagabond Mini |
Does the Einstein work OK in a regular wall outlet? |
| Author: | pepe88 [ Wed Jul 09, 2014 11:19 am ] |
It works just fine on a regular outlet. |
| Author: | Technical Support [ Wed Jul 09, 2014 2:00 pm ] |
Is this with a fully charged battery? Are you certain your model lamps are off? If the battery is 3 or more years old, it may be reaching its end of life, and this could be the reason. Einsteins charge differently than the WhiteLightings, so that could account for the difference there. Incedentally, which WhiteLightning are you using? |
