Sun Jul 27, 2014 11:27 pm
Can the nikon d90 be used with einstein 640? Thanks
Mon Jul 28, 2014 9:40 am
yes. Einstein can be used with any camera with manual settings and a standard flash contact.
In this case, the D90 does not have a PC flash sync terminal, so you will need a hotshoe adapter or a radio remote system, like our Cyber Sync system.
http://www.paulcbuff.com/hsa.php
http://www.paulcbuff.com/cybersync.php
Mon Jul 28, 2014 11:17 am
My understanding is that the Einstein has a built-in optical slave, like the Alien Bees, so "old school" optical triggering is another possibility. With my own D90, I've used (a) the pop-up flash set to manual and low power, (b) the pop-up flash with a gizmo to block the visible light and let the IR pulse through, (c) a speedlight set to manual and low power, and (d) a cheap chinese IR trigger from ebay.
But then my own situtation (small shooting spaces, short distance between camera and strobe) is favorable for optical triggering.
Mon Jul 28, 2014 9:42 pm
Thank you for your replies. Also i want to take picture of my baby girl in doors like newborn pictures, should i get a soft silver PLM umbrella or a white one? I know i would need a front fabric diffuser too.
Tue Jul 29, 2014 9:41 am
Both will work well. I would probably go with the white with the black outer cover and white diffusion fabric.
Also, congratulations!
Users browsing this forum: Google [Bot] and 61 guests
