Sun Apr 11, 2010 10:31 pm
firing. It happens on the light I have the trigger on, so, I pretty much am guessing it is the cybersyncs. Anything I can do to fix it without sending them in? I am pretty busy at the moment and really need triggers(and lights that work :) )
Mon Apr 12, 2010 10:41 am
it sounds like a low battery in the transmitter. Press the test button on the transmitter, if you get multiple blinks, the battery is getting low, if you get no blinks, the battery is virtually dead. One blink, the battery should be OK. If you remove the battery during one of the rapid fire coniptions, and the firing stops, you can bet it is the battery. They run about $4 and are available at WalMart, Radio Shack, Walgreens, and other retailers.
Users browsing this forum: No registered users and 3 guests
