| CAN YOU PLEASE VALIDATE THIS IDEA http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4516 |
| Author: | manuller [ Mon Jul 28, 2014 9:40 pm ] |
| Post subject: | CAN YOU PLEASE VALIDATE THIS IDEA |
This idea was on my mind the whole weekend. Hope anyone here can confirm it works. So lets start with a 64" Soft Silver PLM with the White Front Diffuser Fabric in place. On top of that you add a Black Front Spill Kill Fabric with a: -30" x 60" cutout to act as a softbox -14" x 60" cutout to act a giant stripbox Do you think it would work? if so, what would be the drawbacks? Any help appreciated. Cheers. |
| Author: | Technical Support [ Tue Jul 29, 2014 9:26 am ] |
| Post subject: | Re: CAN YOU PLEASE VALIDATE THIS IDEA |
The soft box idea would probably work OK, though the strip box may or may not, as it is so skinny. Remember, the lower half will have the light and stand blocking part of the light coming out. The bigger the surface area, the less of an issue. Generally, my only concerns would be keeping the Black Outer Cover taught against the Diffusion Fabric once a hole is cut into it. Also, that is a lot more volume to deal with (especially with the strip box) than a dedicated softbox. And you will not be able to use a grid. Lastly, the 64" measurement is across the arc of the PLM. The open face is about 54". |
