| Vagabon Mini not working http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4544 |
| Author: | mi5a [ Wed Aug 20, 2014 6:35 pm ] |
| Post subject: | Vagabon Mini not working |
Hi, the battery charges and all the lights go on, but when I plug a light or via usb, nothing happens no power comes out. |
| Author: | Technical Support [ Wed Aug 20, 2014 6:42 pm ] |
| Post subject: | Re: Vagabon Mini not working |
Do you get a green light next to the USB port? If not, check your fuse, as the "fuel gauge" lights bypass the fuse. Also, do you get any other color from this light? If you do get a green light, then there is likely an internal issue in the VML inverter that would require service. Customer Service can assist you in arranging the repair, or you can visit this page for repair information: http://www.paulcbuff.com/repair.php |
